Top is the switch out of my Pinz, Below is the VW switch dismantaled
They are identical down to the wiring colors. The only diffrence is the handle is 1" longer - yes it even has the hi/low beam toggle
It was listed as a VW Type II turn signal switch used from '68 to '71 poss. part # 211 953 513 G
I've also seen them listed as used for:
SWF turn signal, indicator switch for Bus -
Volkswagen VW bug beetle Kaefer Käfer split window cox 1200 Oval Ovali Brezel KDF Porsche 356 A B C 911 Mercedes SL Ponton Pagode 180 190 220 300 Bus Bully Transporter Adac T1 T2 barndoor Samba Karmann Ghia Typ
Miles
