Window track
Hawkeye Pinz
Window track
Well, it's spring and time to do some Pinz maintanance. I want to remove my door tops, take out the windows and paint them. The window track material is pretty nasty looking and leaks water into the truck every time it rains. Is there a source to find the track? I looked into McMaster Carr, but had no luck. Any suggestions out there?
pinzwheeling
Re: Window track
Why would you want to paint your windows?Hawkeye Pinz wrote:Well, it's spring and time to do some Pinz maintanance. I want to remove my door tops, take out the windows and paint them.
Hawkeye Pinz
Mine are shot too and I want to do this project when it gets warmer. Looked everywhere for a substitute that is cheaper (SAV is like $24 a meter and takes like 3 meters per door!!)
I found various manufactureres of rubber flocked window channel, but none that had the right dimensions.
If necesssary I'll just buy a meter or 2 and do the bottom tracks. That might be enough to keep the rain out at least.
1973 712M
