Wipers
Locked
jacksonpinz
Wipers
Post by jacksonpinz »
Can you get windshield wipers from a local auto store or only from Swiss Army Vehicles. It looks like they make an adapter to take modern blades.
Also, what type of gear lube is recommended in the differentails? 80wt or 90 wt?
If you are lucky enough to own a Pinzgauer, then you are lucky enough!
Get the adapters from SAV or EI. Then you can use easily available blades from NAPA, etc. and also have a choice of the type you want (Winter, Premium,etc.).
80 wt is the recommended.
Paul
jacksonpinz
Thanks for the info.
Locked
