power steering
gunipinzmutt
power steering
Has anybody converted a pinz in power steering? Is there documentation available on this matter?
Gunipinzmutt
Gunipinzmutt
scoutpinzer
Look at www.sdp-pinzgauer.org/html/power_steering.html . Hope it helps.
I took another option:
http://users.bigpond.net.au/profpinz/mo ... eering.htm
1997, 718 6X6 Pinzgauer
Colorado Ron
Hard to say..... Not too long after fitting the PS I modified the motor to 2.7 litres so I gained some hp over the standard setup.
Thinking back though I never really remember sensing that much drop in power after fitting the PS..... Nowdays it's just part of the vehicle.
gunipinzmutt
I will second that request for a kit.
Think about it. I suspect you would have 10 to 20 takers. Look at the EFI kit Jake is making. People came out of the woodwork when push came to shove.
Jamey Rhoades
712M, EFI any time now, diesel trans, line-x, charcoal paint, the list goes on & on, and a smile every time I drive it.
pinzwheeling
Sorry guys, over the years I have had heaps of requests for Pinny components/kits but unfortunately I'm not in a position to help.
Design and prototyping is my business and I treat the Pinzgauer components I build, the same way I would as if I was doing work for any client.
The problem is, all the patterns and components are built using one-off prototype techniques and methods and so along with the design work, I spend tens, if not hundreds of hours on my personal Pinny projects ...... The result is "if" I had to ammetise my design and labour rates into the products they just wouldn't be cost viable.
The reason I put details of my projects on my web page is share information and to stimulate ideas and possibly give those with mechanical abilities a "leg up" so they can build their versions.
pinzwheeling
