OEM seat back suspension.
- mockingbird812
Several of my "rubber bands" have failed. I suppose these are avaialble as new parts, but was wondering if any of you innovators have come up with a suitable substitute.
Thanks.
Sam
Thanks.
Sam
Sam
'71 710K
'71 710K
I use mechanics wire and vice grips. The wire is thin enough that it's not to hard getting the clips in alongside it. Also, the couple OEM straps I've messed with, I softened them up by letting them sit in a coffee can of warm water for a bit before installing them.
Mike Newton 1973 712M (sold)
- mockingbird812
pinzwheeling
- mockingbird812
seat backs
I used sections of inner tube (left over from the MOG) for the OEM rubber pieces. Have to remove the seats from the truck to really pull the tube pieces through. Got them through with safety wire and then needle nose plyers to hook them in the holes. It takes some time to get it but worth the effort.
I also used the same size tube sections (4) over the metal frame of the seat back spaced between the batten holders on the seat cushion. Really makes a difference in the support and they can be used to hold items behind the seat back.
I also used inner tube sections from a bicycle tube to create new rubber for the axe handle holder when mine snapped from old age, just double them up (one over the other) and they work fine.
Morris
73 710M
Morris
73 710M
Use the whole 'loop'. Cut a cross section of the entire tube and use it.mockingbird812 wrote:Interesting idea. How do you attach the two ends of your inner tube pieces together?
I heard just yesterday
from a Pinz parts supplier that Pinzgauer owners were notoriously cheap. Looks like he may be right!
I'll be the first to admit I'm one of those cheap guys when it comes to non-essentials. For the real deal, like engine and drivetrain stuff, I buy what it takes...from the dealers.
- mockingbird812
Re: I heard just yesterday
I suppose the very nature of the Pinzgauer attracts the tuff, rugged, do-it-yourselfer with cheap skate tendencies. Of course, that is the opinion of the man in the mirror.75pinz wrote:from a Pinz parts supplier that Pinzgauer owners were notoriously cheap. Looks like he may be right!
Sam
'71 710K
'71 710K
I found that it is much easier to replace the rubber backing with the seat still in the Pinzgauer, this holds it secure. Use a little WD-40 to lube the channel first. Pull thru initially with a coat hanger, then use a long needle nose pliers (9") to pull and secure the strap while landing the second clip. I installed 2 yesterday by this method. The Swiss still have to have a better way, I would assume.
