As you can see the oil is just below the sensor switch for the Front wheel drive engagement cone, just in front of the Hi Low trans. There is also a leak at the selector cone just behind the front/rear diff. 712.
So if the oil has found its way to the tube do all the o-rings need to be replaced? Cone to diff o-ring, Diff bearing flange o-rings inner and outer. any other seals that may or should be replaced. Also while I've torn the Diffs apart what else should I inspect for wear.
Miles
