Diffs
jacksonpinz
Diffs
I noticed that there are two fill plugs on the Pinz Diff. One is toward the front a little under halfway up. The second is on the rear and a little over half way up. Which one do you fill the diffs from? Same with the tranny. One fill plug on top flush with the tranny under the plate in the rear. Other one is off to the side with a short tube. Thanks
If you are lucky enough to own a Pinzgauer, then you are lucky enough!
jacksonpinz
Don't have the manuals. Ordered them 2 weeks ago from Cold War Remaketing and they have not come. Everything I order from SAV is here in 2-3 days. Has anyone else had trouble with Cold War? Everytime I call to see where the order is I get a message and then it says you can not leave messages. I won't order from them again.
jacksonpinz
Jacksonpinz....I too have ordered a part from Coldwar and have not received it yet, 3+ weeks. I have emailed them and called on several occasions. I have not had this problem with Coldwar in the past, and don't know what the problem is.
Update: I just got a email from Patrick at Coldwar and he says my part is on the way, They have been having troubles with their Voice mail.
Miles
Miles
jacksonpinz
