This has gone from annoying to "I want to fix it!" When I release the handbrake on my 710, the dash light stays on. Sometimes it blinks a few times, so I most likely have a bad contact or ground. I see one wire plugged into the sensor, and it seems solid.
So, what do you suggest, oh fixers of all thinks PINZ?
Help - my Brake Light stays on
I noticed in the parts book at some point they added a protective covering for the parking break switch. I had the opposite problem the plunger was "crudded" in not allowing the light to work when the lever was pulled. Was able to clean it up with WD-40 and get it working again.
Of all the well thought-out and engineered things on the trucks, the placement of that switch was not one of them.
1973 712M
Believe it or not the boot was still there. It was full of junk. I was actually able to remove the boot, clean everything, and re-use it. Not a major victory since a new switch is only about $20, but a small win none the less.Jim LaGuardia wrote:The switch had at one time a rubber boot, no doubt rotted and gone now
1973 712M
