Broken Oil Pump Bolt
While changing the oil today, I felt thru the oil pan to see if there was any sludge on the inside. That is when I felt the bolt. I fished the bolt out and it was a hardened bolt that had broken off with about 1/4" of threads remaining. Pulling the oil pan it looked like an oil pump bolt was missing (the one off to the side and not the two near the gear. Pulling the pump reveals the remainder of the bolt in the block.
Anyone had this happen? I don't know how long its been out, but I've only done one other oil change but don't think I felt inside the pan. The only method I can think of is drilling the bolt and using an EZ-out. Or I if I'm good enough, I could drill the center with progressively larger bits and use a tap to clean the remaining bolt fragments out. Comments?
Kimball
1979 712M
1979 712M
Thanks for the feedback. About 60% of the copper gasket was still there. I'll replace it and the main oil pan gasket.Jim LaGuardia wrote:It is a common failure, usually an easy extraction, use a left hand drill bit and or a scribe. You may have to replace the mating gasket if it is blown out(it is copper)
Kimball
1979 712M
1979 712M
Jim you are The Man! The remainder of the bolt came out with just a little effort. Used the spring loaded center punch in a couple of spots off center, then an awl with an 8 oz. ball peen. Once flush with block, you can use your thumb to turn it out.
Jim there is a steak dinner with your name on it if you ever get out this way. Thanks for your help.
Kimball
1979 712M
1979 712M
