Jack Stand Placement
Locked
JC
Post by JC »
I need to take off my breaks all of them at once and have to lift the 712 Pinz. I have 4 jack stands and want to know where to place the rear ones so that the 4 rear wheels will stay off of the ground. I would rather not have to buy 2 more jack stands but will if that is best. Thanks in advance.
Keep Smiling :-)
todds112
Post by todds112 »
On the SDP-Pinzgauer site there is a photo section on a drivetrain rebuild. They show placing the stands under the rear bumpers. They would need to be taller than the average stands I have seen, though to get the wheels off the ground.
1973 712M
JC
Post by JC »
I was just looking under the pinz and noticed a metal support from the drive line tube that has the leaf spring attached to it could this be a good place to put the jack stand if the bumper is out of reach.
Keep Smiling :-)
Profpinz
Post by Profpinz »
Just put two jack stands under either the rear or centre axle tubes as per you would on the front (and the other two under the front of course)
Providing the check-straps are in good condition the rear suspension will adapt...that is if you put the jacks under the rear axles they will fully compress up against the bump stops and the levelling suspension will push the centre axles down till the check straps take the load.
The same system applies if you put the stands under the centre axles but I would use the rear to limit unsupported overhang.
You will of course have to compensate for the suspension travel height by increasing the height of the jack stands substantially otherwise the tyres on the unsupported axles will remain on the ground.
Have fun with the Brakes!
http://www.ozpinz.com
lindenengineering
Post by lindenengineering »
Give me a break with those brakes!
Dennis
OOOps no customer bashing now
Locked
