Rubber Rub Rails
Pinz Enthusiast
Rubber Rub Rails
Anybody have any info or a line on the rubber rub rails, CWR has or can get them but with all the troubles we all have had lately I dont want to go there, infact the old lady told me impahticaly that CWR was off limits to me untill they get it together, (sorry had to clean the language up incase some youngsters were reading) thinking of checking out SAV as they have 716/718 parts listed just curious if anybody has run across them?
Eric
Anaheim Hills, Ca
1973 712M
1996 LR Disco I
2003 LR Discovery SE
hope to get a 1969 Ford M656
Anaheim Hills, Ca
1973 712M
1996 LR Disco I
- David Dunn
- David Dunn
Erik
The piece on the downslope is nutserted and bolted to the body, and the pieces are also drilled and pegged into the horizonal piece . The horizonal rub pieces are not handed ( I swapped the left for the right side, a groove had been worn into the wood from the previous drivers sliding out over the wood
I read "somewhere" (in my library of Pinzgauer information) that SDP put a lot of thought into the material for the side rub rails.
SDP have often been criticised for choosing wood over more "modern" materials, but there research showed that it was the most applicable for that particular situation.
When the Pinzgauer brushed against an object, (tree, rock etc) rubber rails tend to grip and slew the vehicle off-line.
Harder materials like aluminium had no give so forces were directly transmitted to the bodywork resulting in damage, but wood had a certain ammount of "cushioning" and was less likely to grip than rubber, so it slid along the object. It was also cheaper and therefore sacrificial!
Those original Pinzgauer designers sure were smart people!
1997, 718 6X6 Pinzgauer
That's why i chose trex, benefit of wood but without the rot. Was tired of growing mushroomsProfpinz wrote:I read "somewhere" (in my library of Pinzgauer information) that SDP put a lot of thought into the material for the side rub rails.
<edit>
Those angled rails look like they might catch stuff that could tear them off. I guess they're holding up ok from the look of them...
- David Dunn
Russ
Pinzgauer is still using these same rub rails on current 716/18s. These go back to the P80s and making them road legal in Europe. The laws require that the tires are within the bodyworks, since the axles are slightly longer, enlarging the rub rail was the easiest solution.
Erik, the raised air intake is the stock one for the 716, as are the rails.
I can make a pdf of those pages in the parts manual and email them to you next week.
Dave Dunn
Dave Dunn
