napa auto reference numbers
Locked
TurboJim
Post by TurboJim »
I spoke w my local napa today for a voltage regu;ator and a flasher they dont show a cross reference for the bussman flasher or the voltage regulator and also whats good for battery replacement
It is only air and fuel ...For every 1 lb boost will gain you 10 % displacement
AK NIMROD
Post by AK NIMROD »
TRIED NAPA ...GAVE UP AND ORDERED ONLINE
I ORDERED VOLTAGE REG FROM EXPED. IMPORTS , ARRIVED HERE IN ALASKA YESTERDAY TOOK 4 DAYS.
HAVE TO REPLACE CHAINS FOR CHAIN DRIVE ON MY GATOR SO I CAN FINISH PLOWING THE 12 INCHES OF SNOW WE GOT THEN THE PINZ WILL GET NEW VOLTAGE REGULATOR.
NAPA equivalent of flasher module is #EG23.
EI and SAV have the regulator. SAV # is SAV2606 @ 31.95. EI # is EIC2606 @ 29.00.
Paul
TurboJim
Post by TurboJim »
Sav and ei are backorder on regulators this number is from another post but i didnt have any luck finding it
Alternative parts - Voltage Regulator 28V-30A
Wilson 62-15-6647 (24V) At some Champion Auto and Napa
Thomas-E
V.R.
Post by Thomas-E »
You need to check the other posts, this was just discussed two topics down from this one. :?
Try...
Superior Distribution Center Inc.
P.O. Box 2909
1142 South First Street
Turlock, CA 95381
Toll free: 1-800-457-1728
Fax: 209-667-8208
Order- Renard #35-9128 (24V)
(Exact Replacement for Wilson 62-15-6647)
This is where I found one.
Tom E.
712M
Sonora, CA
TurboJim
Re: V.R.
Post by TurboJim »
in respect for others i didnt want to steel the post from someone else but i did check all those part numbers with napa and they do not list them also superior doesnt stock that number either ...but i did say that earlier :)
Thomas-E wrote:You need to check the other posts, this was just discussed two topics down from this one. :?
Try...
P.O. Box 2909
Turlock, CA 95381
Fax: 209-667-8208
Tom E.
712M
Sonora, CA
AK NIMROD
Post by AK NIMROD »
turbojim- where are you located? if you are needing this up and running soon i might be able to help.
i must have gotten the last 2 from EI.. :shock: :lol: :o :oops: ....so i have a spare.
i could send it to you but shipping will be double since i paid it to get it to Alaska.
Shipping to most places in "America" takes about 3-4 days priority mail.
Thomas-E
Voltage Regulator Source
Post by Thomas-E »
I don't know if they are in stock, but a search found another potential supplier....You might try them, www.rcpcanada.com
RCP PART NUMBER: VRB199-4
DESCRIPTION: REGULATOR, BOSCH 24V
SPECIFICATION:
VOLTS: 24
MODEL TYPE: BOSCH
FEATURES/NOTES: 'B' Circuit
SUBSTITUTE:
N/A
OEM XREF:
6102617 - KOMATSU
21931015 - LUCAS
NCB406 - LUCAS
64800005 - MAGNETI MARELLI
6480005 - MAGNETI MARELLI
505-057 - MOTOROLA
9RH8091 - MOTOROLA
0192033003 - ROBERT BOSCH
>0192033005 - ROBERT BOSCH<
11548806 - MERCEDES-BENZ
21540206 - MERCEDES-BENZ
350477102 - MERCEDES-BENZ
13335 - Old RCP Number
Thomas E.
712M
Sonora, CA
TurboJim
Post by TurboJim »
AK NIMROD wrote:turbojim- where are you located? if you are needing this up and running soon i might be able to help.
Thanks nimrod I got hold of willie and hes gonna send me a used one for now he said should be febuary for new ones
TurboJim
Re: Voltage Regulator Source
Post by TurboJim »
Thomas-E wrote:I don't know if they are in stock, but a search found another potential supplier....You might try them, www.rcpcanada.com
SPECIFICATION:
VOLTS: 24
MODEL TYPE: BOSCH
SUBSTITUTE:
N/A
OEM XREF:
6102617 - KOMATSU
21931015 - LUCAS
NCB406 - LUCAS
505-057 - MOTOROLA
9RH8091 - MOTOROLA
Thomas E.
712M
Sonora, CA
Thanks Thomas are all these part numbers for a direct replacement regulator
Locked
