Jer Bear
Synthetic oil in the Pinz
Jerbearyukon
Can you use it.
Jer Bear
Jer Bear
Jer Bear, I run Synthetic in mine, and have sense i have owned it. I run Red line in it now. but will probly go the Royal Purple on the next oil change. From what i have read the only down fall is that it is a good cleaner so if you have any worn areas covered in sluge after you run synthetic a couple of times you could develope leaks. I still do follow the pinz manual for change intervals.
lucas
Hello. I plan on changing all gear lube on a 710. Would lucas be ok to us with dino oil? I'm not going the synthetic route because I don't want the leaks that come with. Also, The exhaust is directed strait back against the lower control arm and the rear inner boot is melted. How hard will the boot be to replace after I get exhaust turned out properly? AND, The heater ,I wanted to wrap the ducting in heat resistant insulating tape to improve the stock heater. Is this a good idea? The aux heater is a next year project. I get decent heat out of the defroster after several miles. I just need to get the heat to the feet better. I know about the air valve to direct heat to feet. Also, The heat blue lever- up or down? Thanks. Brian
1975 710M
2000 Ural Tourist
2000 Ural Tourist
Hi Brian, Boots are ease for the most part if you replace them with a split boot. from what i have read split boots are considered a timperary repair until you can have shop replace them. Next time I would start a need Topic for none topic related questions I have been lashed in the past for bringing up none topic questions.The exhaust is directed strait back against the lower control arm and the rear inner boot is melted
Beware of synthetics, especially in the portal axles. If(and when) the axle seals leak, it will ruin your brake shoes as it cannot be washed out of the lining at all
Synthetics are a very big waste of money in the Pinz.
This is based on component failure observations.
Also the Royal purple will give poor shift quality in cold weather
Dino oil is cheap and works just fine, $45 for 5 gallons at Napa will do the entire truck for a year(I do however use Redline MT90 in the trans ).
Brian,
After an intensive search, I was able to find GL4-rated gear lube. Pennzoil carries a 80W90 GL4 lube that they call "Gearplus". I was able to e-mail their head office and they directed me to a nearby shop that had some in stock. I have to hand it to their customer service...they went over and above! It's rare in this day and age!
Bob
1990 - Mercedes G-Wagon 250GD
__________________________________________
A goal without a plan is just a wish!
Just catch the leak before it gets to the brake padsespecially in the portal axles. If(and when) the axle seals leak, it will ruin your brake shoes as it cannot be washed out of the lining at all
Jim is this do to the oil or the pinz owner failure to check levels on a regular basis and change fluids on regular itervals. Again Jim I am not tring to start any thing just tring to determine the route of the problem. I have run synthetics every time my mechanic opens it up to check the valves he commits on how clean every thing is and how there is very little sluge build up there. same was said about the portals.This is based on component failure observations.
Jerbearyukon
Check out AircooledTechnology tesing of oil...
For what it's worth you ought to read some of the stuff over at AircooledTechnology. I believe Jake is probably one of, if not the, world's expert on high performance aircooled engines. Most of his work has been done on very high performance VW Type 4 motors, but he also owns and has done a great deal of research on a Pinz.
You can read his lubrication forum here (you will need to request a registration, but well worth the trouble).
http://forums.aircooledtechnology.com/f ... y.php?f=47
Brad Penn is his favorite stuff, but he does some dyno comparisons.
He is particularly adamant that for this type of engine you need the ZP which has been reduced in many newer oils that are otherwise very good oils. But please don't take my word, go read his stuff and judge for yourself.
FWIW
Cheers!
FWIW
Cheers!
Newberg, Oregon
Jer Bear, Man i don't know how you can stand it. What weight of oil are you planning on using? Jim what have you seen as far as synthetic oil related repairs, in the engine areas? Again i have been running Red Line in mine with no leaks. All though these days i have noticed i am using more oil. I think Its time for a 2.6L or 2.7L but that is for another topic.
Jerbearyukon
