Stuck Choke and Gas pedal
LibTimothy
I jumped into the Pinz last night and found that I could not move the choke lever. The gas pedal was also not moving. I removed the service panel and fiddled around with the linkage (At least I think I fiddled with it, it was pretty dark). Now the choke is stuck halfway out and the gas pedal was half way down. And I still can't start it.
Now it was cold out (about 14 degrees) (felt like the inside of a cryogenic chamber) but I have run her this cold before.
I will have time and (hopefully) warmer weather on Saturday to pull the cover and look at all the linkages. All I need to know is..... What am I looking for? Could it be just too cold? (Say it ain't so!)
Thanks in advance!
Timothy
'74 712M
Thanks in advance!
Timothy
'74 712M
When the only tool in your toolbox is a hammer, every problem starts to look like a nail.
Just a poke in the dark here...
Have you made sure the manual throttle pull lever is not in locked condition? There are oil/lube access ports on the cables so you could squirt some nice thin lube into them as a second attempt to free them...assuming they are frozen up.
I will now turn on the lights...
1975 710M
LibTimothy
Cold
I'm not trying to get into a colder-than-thou contest here. At least not with Alaskans on the board. It was just colder than normal (as if ANYTHING were NOrmal in NY) and I was wondered if that could be a factor.
I was hoping it would warm up to freezing today (holy cow! I'm nuts for living here! Will I ever be warm again?) so I can get the covers of and see if I can spot something simple.
So let me confess my sins here..... I have only owned the Pinz since November and it's been so cold out (since August) that I have not pulled off the engine cover yet. I don't know what the enging looks like. I was hoping to go without problems until spring time (July).
So, sins confessed, what should the throttle linkage look like? Could I just have ice frozen on something? Is there a common broken something? Should I take pictures of what I have (once it warms up to freezing). This problem happened suddenly. One day it worked fine, the next not. The manual throttle is not locked. I can pull it and it moves until I reach the point the gas pedal is stuck at. I'll look at lubing the linkage. Again, I was hoping I was just iced up somewhere rather than broken.
I did buy the parts and repair manuals, so I have pictures I can look at to see what the linkage is suppose to look like. But I'm having trouble finding a clear picture of the linkage. I might be on the wrong page in the manual.
Thanks again for all the advice and help.
Timothy
Timothy
Hmm, If I can find someone on the Forum with a temp of more than 37C (99F) I may still be in the running!I'm not trying to get into a colder-than-thou contest here. At least not with Alaskans on the board.
1997, 718 6X6 Pinzgauer
LibTimothy
Still cold, but I think I have it fixed.
Well, it did warm up slightly today and I spent a few minutes looking at the linkage thru the service panel and I think I fixed it.
I'm not sure how I fixed it, but I could see that the choke cabel was moving, slightly, the choke on the rear carb, but not the choke on the front carb. So I was able to grasp the front carb choke with my right hand and the choke knob with my left hand and wiggle them back and forth until it moved.
Then I started her up and it was like nothing was ever wrong. Nothing like a little shaking to make things better.
So that leaves two things: 1) a theory on what caused the problem and 2) a followup question.
1) Cosmic radiation.
2) Should I uncover the carbs and spray some carb cleaner in there?
Timothy
P.S. Profinz, since you live down under you get to take the negative inverse. I.e. - 1/37 C.
Timothy
Most of last week was in the 30's, then for the last few days it's been cold (high teens) .... That's Melbournes weather for you!Peter, would that be right now or in a couple of months?
Hmm....Interesting way of looking at things.Profinz, since you live down under you get to take the negative inverse. I.e. - 1/37 C
In that case I hope it doesn't get any colder for you guys!
Yep, the drought is a BIG problem here too.We are starting the drought thing again here. No rain to speak of since last August. If it is a normal dry hot year here, 105 - 110 F
Water restrictions limit watering the garden to a few hours a week (by hand only) and you can't wash cars at home.
I've just purchased a 4500 litre rain water tank to collect the rain run-off so that should help a little after it fills.
'If" we move to the next stage of water restrictions washing cars all-together will be banned!
Bottle it up Erik and send it over!
