24V winch
Post by Jim LaGuardia »
If you attach the ground at the batteries , it would be wise to put a battery shut off switch in the battery box to terminate ground. this way you can kill the ground when not using to prevent unauthurized use and preserve the battery ground shuttoff keyswitch functions.
Breakers on winches are useless :roll:
Cheers, Jim LaGuardia
"Arch Magus of Machines."
Buzz
24V winch
Post by Buzz »
Thanks Jim, I was planning on using the original cut off switch and I was planning to run the cables all the way back to the batteries.
I will assume your perspective on the breaker is that its very difficult to get the most out of the winch in tough situations if a breaker gets in the way?
1977 712
M Wehrman
Post by M Wehrman »
I took the control box off mine and mounted it under the glove box. It cleans up the front and minimizes the "unauthorized use" issue. It only takes a paperclip to operate the winch at the box..
Mark
Stock means no imagination!
Volvo TGB1317, .95% Morphed!
68 Haffy
Buzz
24V winch
Post by Buzz »
Got a call from WARN this evening. They do not recommend breakers.
1977 712
Buzz
24V winch
Post by Buzz »
By the way, here is a picture of the winch bumper we made for my truck. We reinforced the bumperettes by welding 1/8 inch steel inside which converted them from C channel to box section. Then we built up the middle section. The floor plate the winch sits on extends through the front plate and is held by the pintle pin which will take most of the pulling loads.
If anyone is interested in knowing more I can put up some more pictures. My buddy Bob who did the work is thinking about making more or selling plans.
http://i33.photobucket.com/albums/d74/B ... Bumper.jpg
1977 712
AK NIMROD
Post by AK NIMROD »
HERE IS A PHOTO OF THE HEAVY DUTY BUMPER MY SON MADE AND THE WINCH MOUNT. WINCH IS DETACHABLE AND CAN BE LOCKED IN PLACE
Erik712m
Post by Erik712m »
http://s177.photobucket.com/albums/w205 ... bumper.jpg[/img] Buzz good looking winch mount. I choose to have the bumper http://s177.photobucket.com/albums/w205 ... bumper.jpg can some one tell me how to post pics again?
AK NIMROD
Post by AK NIMROD »
ERIK- in photobucket just click on choice below the picture that begins with img......bottom one IMAGE CODE that copies it then just paste it in the message.
Erik712m
Post by Erik712m »
[img][img]http://i177.photobucket.com/albums/w205 ... bumper.jpg[/img][/img] Thanks Aknimrod i have struggling with posting pics for some time. FYI Andre in Cal made this winch bumper he is a member of the forum
Buzz
24V winch
Post by Buzz »
Thanks for the reminder on how to post pics
1977 712
Denis
Post by Denis »
Good day :D
Here is my take at putting a winch on my Pinz. I build the bumper and like Morris the controls are inside on the side of the right foot well.
On both sides, under the aluminium plates are small boxes to store shackles and small stuff.
Denis
Jerbearyukon
Post by Jerbearyukon »
:D Very nice Denis - you have put alot of thought and work into it.. Again I have to comment on the paint job - If nobody else has seen the work on the inside you should post it...I think it looooks GREAT
Jer Bear
bernhard
Post by bernhard »
Wow every ones posting picks of there creation. Better get in on this
Bernhard
1973 712M
1975 710K
2013 Tacoma TRD 4X4
Too clean
Guys, geez, come on... those fairleads are WAY too clean and shiny.
Can't you find a Jeep to pull out?? At least a Kia? How about 3ft of mud to get stuck in?
:roll:
Locked
