Is it the stock carburated engine or are these the 2.7's with EFI.
My 710M, as far as I know, is all stock, except the ignition, and it likes the 52 to 58 mph range. It will do 62-63 mph okay, but that usually requires a tailwind unless I have the pedal way down.
I don't normally need the speed, I'm getting about the same gas mileage as Jim mentions in his last posting on is EFI available now, but my Pinz doesn't like running at basically idle speeds off highway or on inclines. Those two places unfortunately are where it spends alot of it's time.
So, what is the cure or how does one mitigate that? Is EFI the only answer and will it give the Pinz more top end speed?
Andy
