This had been discussed some time ago but since it happened to me I thought some of the newer guys might have missed it.
http://www.swpinzgauer.org/message_boar ... p?f=7&t=59
tranny linkage
tranny linkage
This is one I had not heard of, I will have to check it out this weekend...
Pinzing is AWESOME.
Seems the common signs of an issue are a sloppy shift pattern or a large pattern. The shift pattern should be very small if all is working and adjusted properly. I could almost hit my heater controls when putting it into 4th. The tranny would shift fine just required a lot more travel of the shifter. The linkage had been "welded" in a couple of places and the gusset was added before I got it over 4 1/2 yrs ago.
Just a heads up when you are crawling under the truck. Just glance at the corner and connection points.
Well that's good news....As I remember the pattern on mine is quite small, and not sloppy...but as I crawl around under there, I will give that area a real good look.... thanks again.Seems the common signs of an issue are a sloppy shift pattern or a large pattern. The shift pattern should be very small if all is working and adjusted properly.
Pinzing is AWESOME.
