Rear Door Latch
Locked
Kirby
Rear Door Latch
Post by Kirby »
Recently I had my rear door latch stop working, I took it apart and could not fiquire out what is wrong with it. I did not have my manual with me, so I took the parts with me. This week I plan on looking at the detailed picture in hopes I can spot the problem. It would not latch when closed.
Any advice? :? Would I have to buy a whole new latch or are the tiny parts inside the whole assembly available?
By the way a bungee cord works great to hold it shut! :x
Should not make a difference, but this is on a 712M and is a single door that swings Right to left... and yes the tire hangs on the door! I suspect that could have created extra stress on the assembly?
Pinzing is AWESOME.
Twin Pinzies
Post by Twin Pinzies »
Fiddle with the outer release lever. If it is all the way down, it won't allow the door to latch. If you reposition that lever, it usually works.
Trial and error the outside latch until it catches.
Kirby
thanks
Post by Kirby »
I fiddled, I cursed, I talked nice to it, nothing worked. As of now I have it apart and in a bag, will pull out the book this week.....
Pinzing is AWESOME.
Locked
