Dash lights
Dash lights
Does anyone have the number for the light bulbs in the dash or can you tell me where to look? The light bulbs I'm talking about are like the ones for the blinkers, the emergency brake, the 4500 rmp light etc. I have some that need replaced and someone already got the convoy light bulb and the one for the heater. Thanks.
Andy
Andy
michaelh712
Lightningpinz
michaelh712
lights
When I lived in San Diego there was a store called LightHouse that I got all my 24v bulbs and lights from. I have a catalogue from GROTE Industries. Phone is 800-628-0809 and their email shows on the back page as safety@grote.com
Hope that helps. There are other sources for 24v stuff but I have not had to use them.
Morris
710M
Morris
710M
- David Dunn
after dealing with NAPA for a while, I called a local auto parts house and they located the proper dash lamps plus stop, tail and clearance lamps for my Supacat ( it's 24v, the Pink Cow is 12v.... go figure
Wagner #
17063 for dash lamps 24v 1.35cp
17643 for stop/turn lamps 24v 36.61 cp
17181 for clearance/tail lamps 24v 3.98 cp
And for those that forgot,
http://www.sdp-pinzgauer.org/html/parts_reference.html
Wagner #
- David Dunn
Andy
Are the same dash lights burning out? or just a random old bulb? If replacement bulbs are blowing, it could be a sign of overvoltage, and regulator isn't doing its job. Put a volt meter somewhere and run the engine at high rpms to make sure you're not spiking. Excessive voltage will eventually take out your Pertronix ( if you have one fitted).
I also have a cross reference list for USA, Lucas, Osram, Philips and Stanley bulbs. Now adding the Wagner numbers to it.
Dave Dunn
Dave Dunn
