Removing Front Door Hinge Pins on Pinz?
Any recommendation as to how to remove front door hinge pins on Pinz?
I would like to replace with quick change pins for easy door removal for summer,
Twin Pinzies
hinge pins
.......by now I think you have it.
I had to pound one out from the bottom with a slim punch, but they all came out after release oil being applied.
Putting in removable pins is great, (I was installing door locks and new seals this weekend) they are so easy to remove if something needs to be done. Great for the desert.
Morris
Morris
Two items of advice...
1. Be patient with the application of penetrating fluid! (Use copious amounts - It will make your job with the BFH a lot easier!!)
2. Use the BFH very carefully! You can shift the hinges on the door side.
While I had my doors off, I changed out the screws with hex-head ones from Expedition Imports. They work a lot better than the originals.
Bob
1990 - Mercedes G-Wagon 250GD
__________________________________________
A goal without a plan is just a wish!
- GenevaPinz
texas pinzgauer
BFH....cute! How could anyone from Texas NOT know that?
When I used to work as a roughneck offshore years ago, we used to refer to the lead man or boss of the rig as the "HMFWIC".
You can PM me for the translation.
1974 712M - sold
1973 710M - sold
1974 712M - sold
1973 710M - sold
