green lights for dif locks
Replaced bulb for rear dif lock but still not working...any sugestions. Thanks Zig
Check the wire and connector for the sensor switch at the rear diff. My connector had gotten all dirty and corroded (and loose). Cleaning and tightening did the trick. Might as well check on the others, front diff and 4x4, while you're under there.
Hope this helps.
Hope this helps.
Lightningpinz
And then,
And then, if still not working another place is a white molex connector. Remove the dog house cover. On the passenger side where the wire harness and the hydraulic pipes go thru follow the wire bundle down looking for a white moles connector with ... if memory serves therr are 6 wires into and out of the connector. From the connector, the wires go down the central tube to the covers mentioned earlier. Many times this connector is loose/corroded, etc.
