valve adjustment tips ?
Locked
norcal pinz
Post by norcal pinz »
hi can somebody give me some tips on valve adjustment what is the proper clearance ? thank you
710M 1972
710k 1974
norcal pinz
i looked in the book and i have done this before but cant find the page that tells me what to set the valves at how often do you guys adjust your valves? in the pinz
710M 1972
710k 1974
Post by Jim LaGuardia »
.2mm or .0078" for all valves (adjust cold) :roll:
Cheers, Jim LaGuardia
"Arch Magus of Machines."
norcal pinz
thanks jim do you happen to know the points gap and plug gap as well :D :D
710M 1972
710k 1974
Post by pinzinator »
Pistons in cylinders 2 and 3 are at TDC at the same time, and so are pistons 1 and 4. Determine which cylinder is at the end of the exhaust stroke and set those two valves.
norcal pinz
my feeler guage doesent have 2mm or.0078 i dont get it could it be
.007/.178 mm
or .008/.203 mm
or .009/229 mm sorry if this is confusing :lol:
710M 1972
710k 1974
milesdzyn
Post by milesdzyn »
Norcal, go with the .008/.203 mm feeler and you'll be good to go. Use the feeler to do the adjustment and recheck the gap after tightening down the nuts, as they may get off while you tighten them. Check them again after a couple runs.
Miles
'73 Pinzgauer 712M
Locked
