I just ran into the first event that forced me to send my Pinz to the repair shop... it might be pretty mundane as I am mechanically challenged
I used the Pinz last Friday night with no problem. I wanted to start it again Monday morning and there was no idle: as soon as the engine started, the revs went up to about 80% of the maximum without any action on the throttle (so pretty high, and not the kind of revs you want to keep when starting...).
I checked the throttle return spring, throttle control and starter control outside the carbs and everything works as usual. The repair guy had a quick look inside the carbs and the throttle valves seemed to work properly...
Any ideas?
Thanks in advance,
Jan
