Fuel tank drain plug leak?
Locked
tfrooney
Post by tfrooney »
After letting my 710k sit for a couple years I'm getting it moving again. In the process I thought I'd drain the old gas from the tank by removing the drain plug. It was hard to free up and came loose with a loud bang. Once free it unscrewed smoothly. So smoothly that it dropped into the funnel I was using to catch the old gas. Boy does that gas flow fast! The plug hole is large. Too large to block with a finger. Good thing my son was able to go get a second gas can to catch the remainder of the gas. It was a tense few moments as I was drenched in gas and plenty was spilled on the ground.
Anyway, my question is now that I have fresh gas in the tank why isn't the plug sealing well. I have a slow drip even though I've tightened it pretty good. Do I need to replace a washer? Should I use teflon tape?
Thanks in advance, Tom
73 710K
Post by Jim LaGuardia »
Replace the washer, you can use liquid teflon pipe sealant, but not teflon tape.
Cheers, Jim LaGuardia
"Arch Magus of Machines."
ka
Post by ka »
those washers are designed to squash into shape on 1st install. after that they're pow. they also get hardened by that 1st squashing.
1973 710m
tfrooney
Post by tfrooney »
So, now where can I get these washers? What size are they?
73 710K
ka
Post by ka »
they dont have them at swissarmyvehicles?
1973 710m
norcal pinz
Post by norcal pinz »
i need one too.
710M 1972
710k 1974
Napa # 704-1364
M Wehrman
Post by M Wehrman »
Coupla years... :shock: :shock: I bet that smelled just peachy! :lol: :lol:
Stock means no imagination!
Volvo TGB1317, .95% Morphed!
68 Haffy
Post by pinzinator »
Every year or so I'll run the Pinz down to where there's almost no gas in the tank. Then I'll pull the plug and drain the gas out and use it in the lawnmower or dump it if there's any crud or water. Never had a fuel system problem yet.
Ditto the every-other-year draining. But I toss the old stuff into my deuce & 1/2, good or bad. That thing eats anything: old gas, fuel oil, deep-fry grease, old cats, anything! OK, it doesn't really run on old cats.
Still rather drive my Pinz, though. It smells better. :)
Sorry, I'm up too early.
Locked
