I am trying to remove the alternator in order to replace the condenser,
which is well and truly stuck in. However the alternator refuses to
move at all as if it is welded down? The clamp lever has been loosen
and prised open a way and the bolt holding the clamp lever in position
has been wound out, but no movement at all, up or rotational! I have
even tried moving the flywheel on a bit to see if it is sticking there
but no joy. Surely this is not normal? Is it likely to have stuck down
with muck and age or am I missing something?
What have other people encountered?
Jon
'76 710M 62,000km
I live in Wales, but come "from off"
Alternator removal problems. What am I doing wrong?
honeyrustler
First off it is obvious you are not familliar with the components of your engine
The alternator has a fan and is part of the charging system, what you are describing is called an ignition distributor.
To free up a stuck distributor you need to soak the area around its base with penetrant and let it sit overnight, then take a large screw driver and a hammer to tap it in each direction till it frees up.
Once out, you will need to clean the bore and replace the seal before re installing. Use visegrips to clamp onto the old condenser twist and pull to remove it or drive it out with a punch.
It is a pain, but once freed up and greased, it should stay freed up
honeyrustler
Oops!Jim LaGuardia wrote:First off it is obvious you are not familliar with the components of your engineThe alternator has a fan and is part of the charging system, what you are describing is called an ignition distributor.
Thanks for the advice.
Jon
'76 710M 62,000km
________________
honeyrustler
