Can't even guess how it happened, maybe got stepped on? Anyway I have a large crack (4'') in the left front of the cover, at the corner, what do I use to repair it?
Morris
crack in maintenance cover
I used super glue and painted it again with rattle can flat black. I can still see the crack but it is not moving.
I used the Loctite Plastix Bonder, a two-component epoxy for plastic, comes in a double-syringe packing. Worked great for large cracks in the front two lower corners, but not so good on the flexing rear edge. Maybe it was my lousy prep on that side. Then I got some kevlar or aramid 1" wide tape from Jonestown Distributors (10 yards for like $20 delivered), and used the same glue over the cracks. That did it for good. Fiberglass tape might work too, but kevlar was less itchy. The price on a new cover is truly scary.
I also changed the seal. The replacement one sold by SAV is of proper dimensions, but it seems to be much harder then original seal. Used 3M
Weatherstripping glue (pale yellow version color) and that worked great. The only problem is that it takes some force now to press clamps (all 4).
No big deal, but I hope that stress won't create new cracks. If it does
I'll let everybody know. Inside cover, the insulation was chewed in few
places. I noticed that some rubbery compound was used for a repair before, so I used Permatex Black Silicone Adhesive sealant. Although not technically a filler, it did a good job. I used spatula to smear it over the holes in insulation.
OG
