Sorry but I saw this on a post before and I have searched to no avail.
Can someone point me to it please..thanks
Jer Bear
After market parts
Jerbearyukon
http://www.goatwerks.com/interchangelist.htm Are you talking about the parts interchage list?
Jim L. Your website is looking nice.
Jerbearyukon
Jerbearyukon
Distributor cap
Distributor cap can be replaced with a 75 or newer volkwagen superbeetle distributor cap too ok
Info from Dennis W
Thanks den
Info from Dennis W
Thanks den
Re: Distributor cap
All the information is already out there one just has to read.Jerbearyukon wrote:Distributor cap can be replaced with a 75 or newer volkwagen superbeetle distributor cap too ok
Info from Dennis W![]()
Thanks den
"Pertronix" replaces the points inside the distributor with a solid state sensor. The previous owner of my 710M changed to civilian (NGK) sparkplugs, using a replacement plug wire kit that still uses the original (screw-on terminals) distributor. Another kit uses a replacement (modified Porsche 009?) distributor so that you can use any civilian wires. Pertronix is spectacular. I'm old enough (50+) to remember having to reset and replace worn distributor points on a regular basis. With the pertronix, it's pretty much set-and-forget.
Jerbearyukon
