Resistor and fuse pack jumper plug
OMG who thought this was a good idea. I either need to replace or make a new one of these things. It's the little connector under the dash that has several resistors on the back side and a few little bridge fuses inside. One of the resistors broke which isent a big deal but the little fuse bridge also crapped out. This is a bit harder to repair. Options are to replace with factory part or make a whole new setup that would be more user friendly. So, will I be able to find the factory part? [/code]
I think this might be what you're referring to:
http://www.pinzgauer.com/showdetails.ph ... 111850690U
Group 09-40-55. SAV has at 115.28 new. I bought a used one for 25.00 from them a while back since I had no idea how to make one.
