Washer pump replacement done
Locked
todds112
Post by todds112 »
I made the $16 Haflinger pump from SAV work. You have to remove the chrome bezel and enlarge the hole. I also had to get a check valve to make it work.
The check valve is from McMaster-Carr ($3.97).
Set-up works as well as the original for alot less coin.
1973 712M
Very nice job, Todd. I think I'll copy your work. Do you happen to have the check valve part number?
norcal pinz
Post by norcal pinz »
yeah i like that!
710M 1972
710k 1974
todds112
Post by todds112 »
McMaster-Carr part number is 6079T51, nylon check valve, 1/8" barbs.
1973 712M
andy
Post by andy »
Nice job. I'm so glad we have so many talented individuals, with so many good ideas, on this board.
Andy
A bar F
The buck STARTS here
www.deerleaseservices.com
Locked
