Putting wheel drive back together....
Locked
jacksonpinz
Post by jacksonpinz »
Had a hub seal leak on the rear axle at the wheel drive. Dissasembled and ready to put back together. There is no gasket between the backing plate and axle. Instruction manual says to "coat sealing surface with sealing compound". Any suggestions on what sealing compound they recommend?
BTW, real fun job, not!
If you are lucky enough to own a Pinzgauer, then you are lucky enough!
Lorenz
Post by Lorenz »
Universal Sealing Gear Box Compound
In Germany we take often "Hylomar"
Post by Jim LaGuardia »
Use Permatex aviation sealant or Anerobic sealer.
Cheers, Jim LaGuardia
"Arch Magus of Machines."
Locked
