4500 rpm light Is there a test?
Locked
norcal pinz
Post by norcal pinz »
i'm wondering if there is a way to test this system i have never seen my light come on and i want to know if it works properly. also don't know where it connects to ,the engine somewhere ? thanks everybody!
:D
710M 1972
710k 1974
Foz
Post by Foz »
4700 rpm oughta do it
Foz
ka
min rpm's??
Post by ka »
on this note, does anyone know the min rpm's? i just noticed that the other set of numbers is refering to low range max rpm's. i always thought it was min because i never looked close enough.
1973 710m
todds112
Post by todds112 »
When you first turn key on it should flicker. I still wasn't convinced mine was working so I ran it up in low range till it came on. It REALLY made a racket. I don't suspect you would ever see that RPM in normal use.
1973 712M
Post by Jim LaGuardia »
If the light flickers when you first turn on the key, the module has passed it's function test.
You know, you could just install a tach if you just have to know the rpm's.
Cheers, Jim LaGuardia
"Arch Magus of Machines."
norcal pinz
thanks guys for the flicker info i cant wait to check! tach no way i like them bone stock who needs that when your practically sitting on the engine right.
PINZGAUERS RULE! thanks guys.
710M 1972
710k 1974
MarkPinz
Post by MarkPinz »
Mine came on once while descending a long steep grade on the highway :shock:
Just get in and go....
norcal pinz
downhill on the highway you were probably hauling ass and it came on to say slow down.
710M 1972
710k 1974
Locked
