Mark
TD trans capacity
TD trans capacity
Well I looked for obvious postings for this info and I know I read it on the forum. I also know I may get the evil eye
from Dunn for not looking .
I also figure Eric will find it and put in a link,as he has an uncanny way of finding this stuff,kinda like the Real forum's bloodhound
I'm only blind in one eye,just can't see out of the other.....
Mark
Mark
Stock means no imagination!
Volvo TGB1317, .95% Morphed!
68 Haffy
68 Haffy
- David Dunn
Welllllllllll, if you go by TD manual... it takes 7.0l, including the oil filter. BUT , I don't think you're talking about an autobox.
The manual gearbox takes 2.0l.... and if that is any different than the standard 710/12 trans, I'd be shocked
... it's the same case. Of course it could hold more oil if tilted to the left, than the right
Vince, insert Big cyclop eye here X
- David Dunn
M Wehrman wrote:On a past post someone said the TD box held less lube. Thanks David for the clarififation.
Mark
I had Confused one of Jim's post.
twenty some thousand post things start to run together at times.They tend to burn up quicker when you run them low on oil due to the steep ratio's
And Dave before you post I would just like to say
I found smileys.
- David Dunn
- David Dunn
M Wehrman wrote:Eric,
Perhaps you may redeem yourself and share your new emotiocons ( whatever,the smiley guys w/attiudes are called) with me.Then we can BOTH bless the community!![]()
Mark
Here you go. http://www.freesmileys.org/smileys.php
