Coil specs for use with Pertronix
Need to find a coil for use on a 24volt Pinz that has the Pertronix upgrade. Any recommendations as to what brand to buy, and part number?
I can confirm, Bosch blue is a very good way to go. Make sure and ohm it, as there are two variants out there. (one claims to be without ballast, but is not 3 ohms) You want the 3 ohm one as Jim indicates.
Electrically these are identical to the factory coils, slightly hotter output than normal beetle coils, just in civvy housing. Seem to be a bit hotter spark, but not enough that you get into coil heating issues like some aftermarket.
Pick you up a raincoat off a BMW at a junkyard and you are in business:
http://pinztrek.com/pinz/mods/pinz_mods.htm#civ_ign
This worked well even in FL water.
Have fun,
Alan
Have fun,
Alan
