top bolt on the starter , tough .
norcal pinz
im having trouble removing the top bolt from the starter in my 710k i thought i had done this before but i guess not. I removed the wiring and the dipstick and the bottom bolt but the top one is such a tight squeeze i can barely get the wrench in there im thinking about cutting a wrench in half so i have room to swing it around?
i broke it free i just cant turn it any suggestions would be handy .
710M 1972
710k 1974
710k 1974
Yeah I had no problems removing mine, Just took the whole body tub out of the way.
Miles
Miles
'73 Pinzgauer 712M
'73 Pinzgauer 712M
It takes a few minutes to remove the clutch slave....you don't even have to disconnect the line/hose, so it's simply a matter of re-bolting it back in place when you've finished.
or, you could use Miles's method!
1997, 718 6X6 Pinzgauer
norcal pinz
