Starter backplate causes loud grinding when fail
norcal pinz
if you hear a loud metal grinding on metal sound ,Sounding like you push the starter button in while the engine is running (not good) chances are its your starter backplate . with the engine running grab the starter and push and pull on it to see if there is any grinding. replace the backplate good luck.
710M 1972
710k 1974
710k 1974
