valve clearance
Engine troubles? Try here.
blackstack
valve clearance
Post by blackstack »
On page 142 of the Operating Instructions book, in the explanation of finding TDC it uses the term"....valves must overlap" What does this mean???
Post by pinzinator »
Both valves are open at the same time, this happens at TDC of the exhaust stroke.
blackstack
Valve job vocabulary
Thanks!!
David Dunn
Post by David Dunn »
pinzinator wrote:Both valves are open at the same time, this happens at TDC of the exhaust stroke.
Actually, when they're closed.
The top of the compression stroke .
TDC is the basic reference for setting ignition timing on the compression stroke..... for instance, if you hear 6 degrees before top dead center (BTDC) , the timing is set to ignite the spark 6 degree before the compression cycle is complete (TDC).
blackstack
clarify my understanding
From page 142 of Operating manual...(paraphrasing)To set valves of #1 cylinder crank engine till both valves of #4 are open etc.....is my understanding of statement correct?
David Dunn
Re: clarify my understanding
blackstack wrote:From page 142 of Operating manual...(paraphrasing)To set valves of #1 cylinder crank engine till both valves of #4 are open etc.....is my understanding of statement correct?
With your last statement, then Pinzinator's statement is correct.
When both vlaves of #4 are in a open position when #1 are closed, and ready for adjustment.
