34" tires on a 712
Higher Ground
34" tires on a 712
Post by Higher Ground »
I know that the question of tires has been to death , what tires last a long time on the pinz. ? I know on a older Ford truck they don't seem to last more than 50k due to the camber chainges . Once I get my pinz. I plan on installing some 34" x 9.5 16 swampers . If I could I'd get Simex tires but they aren't availible in Canada . Will the Swampers have any problems with rubbing at 34"
dokatd
Post by dokatd »
I have had zero issues with rubbing on my 34" swampers. My truck does not have any of the tanks or boxes on it though. My truck has been heavily wheeled.
Profpinz
Post by Profpinz »
I used to run 34" Swampers and they VERY rarely rubbed.
I now run 35X10.5" Simex ET's and when the front suspension is compressed and the wheels are turned they do rub slightly, but nothing really to worry about.
1997, 718 6X6 Pinzgauer
dokatd
Post by dokatd »
But Prof, I thought 34" plus tires on a pinz was a very poor decision and could only result in broken axles from tire rub etc. :roll: :roll: :roll: Oh, wait Im sure you just cruise the mall parking lot like I do. :lol: :lol:
pinzwheeling
Post by pinzwheeling »
The RTPT had approximately 34" tires which worked fine under a moderate load. However, the added weight of the RTPT and more severe (moderate for most folks, but the RTPT is a bigger animal) wheeling resulted in not one, but two broken axles due to rubbing the body of the truck.
Trust me, it's an expensive proposition, so make sure that your tires do not rub.
Michael
Looking for a deal on a Toyota or used car?
email: rosenblumm@gmail.com
Profpinz
Post by Profpinz »
Good point, whilst I've never broken an axle (I know of only one Pinny in Oz that has broken one, and you can see/hear it happen here...... http://www.youtube.com/watch?v=-0KGtzb85g4 ) I have had a front stub axle bearing go.
Whilst I concede"rubbing" probably contributed to this damage, in the 10 years of running 34"-35" tyres this is the only damage I contribute to the tyres ..... I probably would have far more damage (both vehicular and personal) if I hadn't run such tyres purely from the extra effort and strain of trying to get up and down the harder tracks :wink:
wrangler0511
Post by wrangler0511 »
Here in Europe 35" Tires are considered to be the maximum.
They do rub occasionally but really nothing to worry about.
I have seen a few axle shafts break but those were situations
where something had to let go....
@pinzwheeling:
are you sure the wheel drives were glued on correctly with Loctite 270?
The centering bolt is not designed to take the stress. I't is just there to mount the wheel drive correctly.
I had two sheared off bolts on a Pinzgauer that was barely
used offroad. Guess what no Loctite was used.
The other ones that I built up myself had zero issues up to
now.
Richard
pinzwheeling
wrangler0511 wrote:Here in Europe 35" Tires are considered to be the maximum.
@pinzwheeling:
now.
Richard
Good point, the actual part that broke was that the locking pin spun around in the housing and destoyed both. Either way, if the tires hadn't rubbed on the body, no damage to the wheel drives would have occured.
Michael
Erik712m
Post by Erik712m »
I'm up for new tires. So I had the tire store fit 34 * 12.50. just to see. I noticed some rubbing on the tank guard when turning .
wrangler0511
Yep 12,5" is definitively too wide at least in the 34"-35" diameter
range.
@pinzwheeling:
You are right every hard contact of the Tires with body parts
should be avoided and will result in damaged parts.
But slight rubbing won't do anything.
Richard
pinzwheeling
wrangler0511 wrote:Yep 12,5" is definitively too wide at least in the 34"-35" diameter
range.
@pinzwheeling:
Richard
I checked clearance before the trip, but bouncing around on the waterfall took away the little clearance I had. I had assumed that I might rub a little, but it turned out to be too much.
Operator error for sure, I had ample opportunity to back off the obstacle, but I had made it up there in three different trucks over the past 3 years.
Michael
ABSOLUTSECURITY
Post by ABSOLUTSECURITY »
So
33x12.50R17LT
Would be OK?
BUT
35x12.50R17LT
Would be a problem??????
or is it the 12.5 wide part that is the issue???????
I just got 7 new GT rims in matte black powder coat and looking for the right rubber in 17"
What am I gonna do with my 7 almost new LT285/75R16 interco trxus's on like new stock rims with dyna beads???????????
Glynn
Erik712m
Post by Erik712m »
When I first bought my rims I started with 32"*12.50 *17 tires they did rub I bought different springs adjusted the bump stops. Last year and half I have had 33"*12.50 with no real problems. I'll report back in a couple of years how the 34"* 12.50 worked out for me .
ABSOLUTSECURITY
Erik712m wrote:When I first bought my rims I started with 32"*12.50 *17 tires they did rub I bought different springs adjusted the bump stops. Last year and half I have had 33"*12.50 with no real problems. I'll report back in a couple of years how the 34"* 12.50 worked out for me .
When you first bought your rims you started with 32's and they rubbed but 33's didnt??????????? typo ? Or is it because of your spring & bump stop mods?
G
Erik712m
Post by Erik712m »
Yes, 33" did not rub. mainly because of the new heavier springs.
