Espar backfiring
Justin Case
Espar backfiring
I'm having problems with my espar heater backfiring. I have cleaned the plugs and etc. Sometimes it will work fine for two or three times, then it starts backfiring. Is there something I'm not maintaining properly?
hmm
Check when unit is on you don't have allot of air in your fuel line. It should be clear and you should see no air bubbles.
After that Id open it and clean the combustion chamber.
Check exhaust pipe that nothing such as wasps built a nest in it.
And what ever you do I think you should get a carbon monoxide detector and since your a pinz owner go crazy and get one with a digital display.
2X 712AMB Oakland, CA
