How much harder is it to put the motor in a 710m, with the body on?
my body tub is off ,and i am debating on putting the tub on before the engine, is this stupid? i want to put the body on so i can roll the truck around or tow it to another location . thanks guys................
tub on before the engine?
norcal pinz
710M 1972
710k 1974
710k 1974
lindenengineering
I can't speak about installing the motor with the body on because I installed mine with the body off. But I couldn't imagine doing it with the body on, seriously I had enough trouble forcing the motor blocks to line up all at once with it off. Mount the motor mounts first, then mount the motor, but leave the carbs, oil cooler, and fuel pump off so you don't damage them during the body install.
If you want a rolling chassis do this:
Miles
Miles
'73 Pinzgauer 712M
'73 Pinzgauer 712M
norcal pinz
