Well,
1. I found some carpet that is an exact color match
2. The winters are long here
3. To hide the Dynamat sound dampening material
4. The winters are long here
I've been thinking of adding some dynamat/acoustimat/dampening material, but didn't want to see the shiny aluminum finish. When I ran across some olive green carpet that is on a rubber backing I decided to give it a try. Since the carpet is on rubber it can still be hosed out and this would hide any soundproofing materials. The dynamat dampens the metal vibration and deadens the rattles while the carpet will absorb reverberating sound. The dynamat was added to the surfaces under the seats, inside the tunnel, and on the firewall. In the future, I'll add some to the front by the headlights because there's still a rattle that needs to be isolated. Most of the carpeted areas were pretty easy to create a pattern out of newspaper and then trace onto the carpet and cut out. The area around the tunnel and footwell took some time to piece together. You can see some of the foamcore trial and error. Where the carpet needed some backing, I switched the foamcore for plastic sign board (like for campaign signs) so that it would be waterproof too. The carpet is held in place with some velcro stickers.
I don't have a lot of miles on it, but it really does reduce the noise level in the cab. The biggest difference I think comes from the dynamat on the tunnel and the firewall, but the whole truck sounds more solid over bumps and rattles. We'll see how it holds up.
I've never had any luck posting images- so here's the link
http://picasaweb.google.com/wayndar/Pin ... directlink
