Engine Thread Repair
Engine troubles? Try here.
NC_Mog
Post by NC_Mog »
I tried to reinstall the two bolts that backed out from the oil pump. I found that the first one has the threads stripped out from the block. The one that stripped is the one of the holes near the gears with the locating sleeve. Also, the other hole appears to have threads intact, but they seem a little loose till the bolt bottoms out.
Does anyone have a recommended/preferred thread repair for the aluminum block?
Kimball
1979 712M
Post by Jim LaGuardia »
Time sert is best, but Helicoil will also work.
Cheers, Jim LaGuardia
"Arch Magus of Machines."
NC_Mog
Post by NC_Mog »
Jim, do you know what size the counter bores typically are? The one that stripped is the one that has the dowl sleeve so its recessed a bit.
Kimball
1979 712M
Measure the dowel , counter bore is 1/2 of dowel lenth :wink:
Note: Don't forget the copper mounting gaskets .
Boelt63A
Time Sert
Post by Boelt63A »
Jim, What is a Time Sert? I have only ever heard of a Helicoil?
'74 710M Wrecked/Rolled
"The Worm"
'76 712M
718 Turbo Diesel
Great site with lots of instructions:
http://www.timesert.com/index.html
Boelt63A
Post by Boelt63A »
Thanks!! looks like just what I need for a stripped manifold stud!!
CFB
:lol:
"The Worm"
'76 712M
718 Turbo Diesel
