Where can i get 24v relays and would these work?
- audiocontr
Looking to pick up a few 24v relays to run additional lights. Would these work? http://parts.digikey.com/1/parts/748078 ... a-24v.html
- David Dunn
I got one through our local NAPA which is useable as "normally-on" as well as "normally-off". (I don't recall the part number, but it was quite inexpensive.) I used both functions: the normally-on powers my backup lamps and the normally-off powers my blackout light. That way, when I run blackout mode, my backup lamps are disabled.
- David Dunn
- audiocontr
24V switches
Try these guys for 24v DC stuff
http://www.24voltproducts.com/
I am using switches from a UniMog radio box. There were lots of things in the back of my Mog that I saved...cause you never know when you might need something.
Check with the Mog parts people...EI and SAV. Bet they have stuff just like you want. Maybe even Volvo parts places...also, most (edit: older) big rigs are 24v as well, check at truck stops, the bigger ones always have parts racks out in the open.
