OK, I'm not rougher on stuff than anyone else, in fact, I'm actually pretty gentle on my trucks.
I keep having trouble with the rear tailgate doors on my 710M's. It's not the tailgate, it's the panel that houses the latch. It keeps getting loose and wiggly. The internal vertical stiffening bar has broken in two of them... even after I had a welder reinforce them with angle-iron!
Has anyone found a fix for this part of these trucks?
Weak rear door frame panels?
Im glad I dont have this problem as the rear door on mine is not used much, however a good bodyman or auto customization shop would be able to find and reinforce this area if you are not adept in putting in some structural supports yourself. It makes sence that this area would give you problems if you use this truck commercially and would be in your best interest to fix it immediately for the sake of safety, the rear door could open unexpectedly since the pin is essentially all that holds the door locked and with the panel wiggling around may open unexpectedly and injure a passenger.
710M
710M
Twin,
I don't know what your tour work consists of, but could the truck/s get by without a spare tire? Or perhaps mount it elsewhere? Thus lightening the weight of the door?
Another idea might be to mount a steel brace at along the top lip of the side/rear panels. Attached directly over the latch on the rear panel and just ahead of the roll bar on the side panel, it would be approx. 45 degrees, and would stiffen the latch area, I would think. Ugly, but...
What do you haul anyway, gorillas?
Are you perhaps missing this cross brace under the rear corner.
This cross brace along with the original bumperetts really do support the body due to triangulation and creating a box frame member.
Miles
Miles
'73 Pinzgauer 712M
'73 Pinzgauer 712M
- totaljoint
