You are lucky , the servos are available on your side of the pond.
However, they are between 150-250 British Pounds each.
You will find the old boosters full of brake fluid.
I dumped over a Qt out of a C303 booster
Rebuilding them is not advised as they tend to pit badly
If the bores are not pitted and parts can be found, rebuild them.
But here in the U.S. it is near impossible to find a kit
Post up some pic's of the process if you do rebuild them and list parts source or kit numbers.
I have found them in a shop who is specialised in MG / Triump /Aston Martin/.... British Cars.
They are readily availble.
I also have a complete manual for the disk brake conversion
with pictures. I have them in Word and PDF.
Can I send them to someone who can publish it here?
I'm not so familiar with the internet.
Does anyone know if OMT is still in operation? Myself and another forum member have been unsuccessfully trying to email them. Do they speak English there? May have to call them.
I'm investigating another solution from Off Toad Tarvike in Finland.
They have a kit using Willwood discs and calipers, and conveting to Toyota 6 bolt pattern, by suppling a modified original hub.
800 Eur per axle. (wheels not included)
They have to use weld in toyota rims to get the correct offset, and can make them beadlock or normal.
Disc brakes would be sweet,but the different bolt patterns would be expensive and a PITA on my TGB.Too bad there isn't a kit using stock wheels,I would be an owner!
They did tell me they were working on a kit which retained the 8 bolt pattern, but that it would be around 1200 Eur per axle as they have to manufacture new hubs rather than machine original ones.
1974 712M AKA the Banana
1987 718M Now Sold
1975 Volvo TGB1111 Now Sold
1963 404S Now Sold
Yep, you'll notice i'm a poster in that thread.
Its a DIY not a ready kit, so you would need a to find a machinist. Not a show stopper, but extra work.
But i have 2 reservations, 1) It uses parts that are not easily available in Europe (ok fine for most of you guys) an 2) i'm not sure about the studs not sitting on flat faces at the rear.
