I'm curious, what were the first projects you guys did on your first pinz, before the expertise you have now? Small tweaks or massive rebuilds?
Your first Pinz projects?
I recently secured my first Pinz, a 710M.
I'm in the "awe" phase and planning Winter projects.
74 710M
Twin Pinzies
Inspect, clean and adjust the brakes, check water level in batteries if serviceable, adjust valves, tune carburetors, inspect shifter linkages, replace bushings as needed.
Maintenance chart http://www.sdp-pinzgauer.org/4x4_Maint_Chart_ES.pdf
Ed
Ed
- GenevaPinz
To improve the safety of the truck, radial tires are no. 1, IMHO, with improved tail lights a close second (still on my to-do list though...
About the electronic ignition, the mechanic who services my Pinz advised that I keep my electronic ignition kit as a spare as long as the stock ignition is working.
Apparently the stock one is much more resistant to humidity than the replacement...
I dunno what others think about it...
Jan
'72 Pinzgauer 710M
'72 Pinzgauer 710M
I disagree there. The Pertronix units are sealed up. The stock cap only looks like its sealed up.GenevaPinz wrote: Apparently the stock one is much more resistant to humidity than the replacement...
TIRES are number one, like everyone is saying, buy radials first thing. 255/85's are ideal but not as many options, though BFG is a good one.
Twin Pinzies
blackstack
blackstack
All fixed !! The door was dished in beyond repair...I did the replacement/repair myself and billed his insurance 750.00
This is where I got my leds www.buytruckstuff.com NAPA has a harness that makes the job a snap. It is a connector with pigtails long enough to lead over to the stock lights from behind. The stock lights have connector posts. I drilled an extra hole into the stock lights and pushed the new wires thru. Some use the original access hole but it was to tight for me. The hardest part is getting the lenses off the stock lights.
This is a pic of how i did my lights. go one ahead and one back to see them from a distance
http://www.flickr.com/photos/agingman/4 ... 886723729/
feel a lot more comfortable with these bright babies!!
texas pinzgauer
I had to add an interior rear view mirror to both my Pinzgauers when I purchased them. They each already had radial tires so I can't really weigh in on any before or after radial comments.
Seats are also highly recommended. Paul and I have had good experiences with seats from a MB Sprinter.
As others have also noted, no matter how much work you plan to do yourself, you shouild have the manuals and at least become familiar with the various things that the truck calls for.
Goes without saying about the fluids being changed ASAP if you don't know the history on them.
How about some H-4 lights from Scott at EI too! Those made a big improvement. Thilo Kass added some larger higher visability Bosch rear brake light assemblies when I purchased my 712. As these things really just poke along on the highway, i added a BUNCH of reflective tape to the rear of my truck. It's painted white and i was able to add white refective tape that it not even noticable during the day but it highly visible at night. Increasing your visibility at night certainly should be a priority.
You've certainly come to the right place to get some educated responses from others who have been where you are now.
Enjoy your new toy!
Enjoy your new toy!
1974 712M - sold
1973 710M - sold
1974 712M - sold
1973 710M - sold
