Would appreciate comments on the advisability of using this or similar in a Pinz
http://www.sportsimportsltd.com/12vocarvvabo.html
heater
- totaljoint
blackstack
- totaljoint
Used an electric vest for many years for winter motorcycling. You can buy one or build your own. May be better to build one for the 24 volt system (I suspect a 12 volt vest plugged into 24 volts could get real toasty)
http://www.shadowriders.org/faq/electricvests.html
http://www.klr650.marknet.us/diy-Electric_Vest.pdf
http://www.advrider.com/forums/showthread.php?t=927
Keep your trunk warm and your branches are much less affected by the cold.
Ed
Ed
blackstack
i had that heater (to run for short bursts)- one day it took a spill and the plastic fan broke and jammed causing it to catch fire (there is another old thread on the forum about fires with that heater if i remember).
i then bought the one that is all metal on the same website:
http://www.sportsimportsltd.com/us-made ... eater.html
(model S24-2500). it has a high-low switch, i only use low (high= 25 amps, low= maybe 15 amps?) which is ok for warming cold hands. i have it temporarily mounted under the upper rifle holders (for the passenger).
