so, the other day, the speedo stopped working. today was my first chance to look at it. the right-angle drive seems fine. even with it bypassed, the speedo still doesn't work. I even drove around the block with the speedo end in clear view so I could watch it. holding gentle pressure on the end and everything ... that cable aint' turning, so I KNOW it's not the actual speedometer. checked both ends of the cable, and while it may be broken in the middle somewhere, it appears ok and when i turn one end, the other end turns too ... so I suspect it's ok, but I'll look at it closer my next chance. I'm wondering, now, about the inside-the-transmission speedo drive gears. I see from the parts book, there are two gears inside there that mesh together. I'm guessing one has a few teeth missing, now, but I'd expect that only of a plastic gear, given there were no unpleasant noises of any kind when it failed.
soooo, my questions
is the smaller pinion gear able to be replaced without opening up that part of the tranny or do I have to take that front plate/casting off to get to it?
are either of those two gears in there that mesh together made out of plastic?
exploded view at the bottom of this post. http://real4x4forums.com/PinzgauerBBS/v ... php?t=5695 gears in question are #s 4 & 11 #1 is metal and shows no signs of stress or wear and turns freely with no resistance when installed.
thanks in advance
jim
speedometer not working
