Breaker #12 Popping
Breaker #12 Popping
I have zero experience with breakers but my #12 keeps popping and it seems to affect my high beams. Ive looked at the electrical diagrams but would like to know if anyone else has dealt wit this issue or could give me some words of wisdom to help me solve the problem.
Breaker #12
#12 is for the:
headlight relay, emergency flasher relay, diff/4x4 indicator lights
I'd check to see if the hot lead to the locker indicator lights has come loose or is worn thru. It is always live (+24v) so if it touches ground it will pop the breaker.
- westernair
Re: Breaker #12 Popping
I too am now having number 12 issues. Started today while just driving around. When it first happend I would reset it and it would stay working for a few minutes, then after getting home I poped the front dash pannel and looked over the wires I could see for breaks or disconnections. I had installed a wiper delay just yesterday and figured I might have pulled a wire loose. I didn't find anything obvious but fear they are related. Now after looking things over, as soon as I reset the breaker and the key is on, the breaker imediatly trips. Any ideas of what I should look at?
I did check the locker light wires, everything looks good there.
Shawn
62 haffy Bantam
61 haffy 4 door
72 710K - Sold
73 712M - Sold
62 haffy Bantam
61 haffy 4 door
72 710K - Sold
73 712M - Sold
Shame of me to say but I havent fixed this yet-I have two breakers that I plan on installing to see if the breaker is just old(imagine that).
But it is related to the highbeams for sure
Westernair,
Paul C. gave you the loads from that breaker. You're going to need to track those items down, and find out which one is causing trouble. Something's grounded.
I'd start at the blinker relay, because it's simple to get to, and prone to failure (though not in this manner, IIRC). Unplug the power to it, and see if the problem is resolved.
If it's in the locker lights, it's probably not post-indicator, since a ground there would likely light the indicator bulb effected (assuming bulb is good). I'd check the 24 v. going into those bulbs for being loose and grounded.
Then I'd pull the headlights out and see if they're ok, wire-wise.
That's where I'd start. Of course, it'll be something else...
u352,
Well, we weren't going to give you a hard time about being slow. Until you reminded us...
Ditto the advice on the headlights, if you're sure that's what is the culprit.
u352,
- Jimm391730
The breakers DO get flaky over time; I had #6 trip repeatedly, every few minutes. Easiest solution is to replace the breaker.
- westernair
I will begin slowly going through each set of wires and check for faults. My headlights and e-flasher still work so I am not sure if they are on the same cercit. this seems to be the blinkers, and break lights.undysworld wrote:Westernair,
That's where I'd start. Of course, it'll be something else...![]()
u352,
Also anyone have a good wiring diagram, or know of one on line? the one I have is so small it is impossable to read without a magnifing glass...
Don't think it is the breaker it's self. when I push it in the dash and overhead lights dim for a secound before popping. I am pretty sure it is a grounding wire. Would love to be able to read that portion of the wire diagram so I could trace every wire involved.
Shawn
62 haffy Bantam
61 haffy 4 door
72 710K - Sold
73 712M - Sold
62 haffy Bantam
61 haffy 4 door
72 710K - Sold
73 712M - Sold
- westernair
Disregard the small wiring diagram, I found one in my Repair Manual, I had a loose one in my folder that was shrunk to fit on one 8.5x11 sheet and is useless.
Shawn
62 haffy Bantam
61 haffy 4 door
72 710K - Sold
73 712M - Sold
62 haffy Bantam
61 haffy 4 door
72 710K - Sold
73 712M - Sold
If you would like another schematic that's been cleaned up and enlarged, you can get one here:
>removed<
There's a link to the file at the bottom of the page. It's about a 6MB file if I remember.
>removed<
- westernair
OK progress, started at the breaker, moved over to the monster light switch, down threw the flasher, to the switch behind the break master cylinder. The two prong switch back their seems to be the culprate. If I disconnect the wires the breaker quites popping. No break light if I do this though. To test the wires going back from this point I took and jumped them together to see the break lights come on. Yes they do and no more popping when doing this so I think I got it.
Now the question, is this switch a readly found part I can get at a Good Guys or do I need to order it from a Pinz part dealer?
Shawn
62 haffy Bantam
61 haffy 4 door
72 710K - Sold
73 712M - Sold
62 haffy Bantam
61 haffy 4 door
72 710K - Sold
73 712M - Sold
Try disconnecting the items in the circuit 1 at a time till the breaker stops popping, accessory socket and switch, brake light switch and brake warning light, headlemp relay, and hazard switch.
I would start by pulling the brake lamp switch power wire first(the switch can melt and short internally).
It should be fairly easy to find the problem as it is consistant.
The switch is a NON TAPERED VW type for Golf/Rabbit.
It should be a straight thread and use a copper sealing washer.
- westernair
THANKS for the help, problem solved with the new switch. Wires were in good condition so I chose not to replace them.
2.5 hours of troubleshooting and then just an 8 dollar part.
Shawn
62 haffy Bantam
61 haffy 4 door
72 710K - Sold
73 712M - Sold
62 haffy Bantam
61 haffy 4 door
72 710K - Sold
73 712M - Sold
