Slow Cranking??
Slow Cranking??
Wondering what might be causing my pinz to crank so slowly? Ever since I got it back in December it has been very slow to turn over. Even with two new batteries or when I boosted it with my 24v Landcruiser it cranks like every revolution might be its last. Any thoughts would be appreciated.
Re: Slow Cranking??
Got it back from work being done on it? being loaned out? ?? what may have been done to it when it was not in your hands?Malahki wrote: Ever since I got it back in December it has been very slow to turn over.
Re: Slow Cranking??
Oh sorry, grammatical error, should read: "ever since I got it, back in Dec". As in I purchased it back in Dec.
Re: Slow Cranking??
My bad, next year I'll learn to read.
Re: Slow Cranking??
check the grounding straps and could be that your clutch is hanging up a little causing the slower turning.
Re: Slow Cranking??
As I also have a clutch issue, I thought I would add the link: http://real4x4forums.com/PinzgauerBBS/v ... 172#p44172
Re: Slow Cranking??
Is it possibly just an "expiring" starter? I had this issue with my Samurai and each time I took apart my starter and cleaned up the windings, it worked well for a few weeks......dunno, just my nickel.
Re: Slow Cranking??
It turns out the slow cranking was the result of bad batteries. I had overlooked the possibility because I was using the RV batteries out of my brand new trailer. So I assumed the new batteries would be good but I had them tested and they were not up to par. Perhaps they sat dead at the trailer manufacturing plant for some time before being put to use
