Starter Solenoid?
Starter Solenoid?
If I am just a getting a click without any starter motor activity, the best bet is solenoid trouble, right?
Re: Starter Solenoid?
Single click or multiple clicks? Latter could indicate low battery or bad connection to starter.
You could try manually shorting across the terminals, I think (bypass starter button) to see if that makes a difference
I don't know whether this type are prone to sticking but a gentle tap with a hammer on the end of the starter casing might jolt it free
Robin
Pinzgauer 710K
MegaJolt ignition
(upgrading to MicroSquirt)
Robin
Pinzgauer 710K
MegaJolt ignition
Pinzgauer Pete
in this order check....battery output .....then connections..starter button..then go to solinoid....then starter bendix....after that starter
710M
710M
Check the following items: ground strap at starter loose or corroded, dirty or loose battery terminals, low voltage(below 22v). If those items check out ok then pull the starter and bench test it(put power to it) if the solenoid extends the bendix gear and power is coming out of the solenoid when activated , then the problem is most likely in the starter motor(stuck or worn brush and bushings).
Thanks guys, so far... ground strap is solid, no jiggling, no corrosion, battery terminals - check, voltage reads 23.7, it's a single click every time i push the button.
Next step is bench testing. I fumbled with it for a bit, but am going to grab a cheap set of crow's foot wrenches before I mess up that top one real good.
One thing I just remembered was that over the past 6 months or so I did have the starter/solenoid not engage a few (maybe 4) times and would just get a whirring sound. Always when it was cold, and hitting the button a second time would always work.
Finally got back to this project... and, uh, anyone have suggestions for that top nut?
I got a crow's foot on there and managed about a 1/4 turn. Now I have no more angles to get at that thing.
Is that the clutch line sitting right on top in my way?
Try removing the 2 13mm nuts from the slave cylinder and move it out of the way
Well, I was being lazy and not removing the oil filter. Way easier job if you just yank that filter.
Anyway, now that it's off I'm getting absolutely nothing on the bench test. No click, no bendix movement. Still showing approx. 24 volts out of the batteries.
Solenoids seem like they might be hard to come by?
Bring your starter by and I may be able to fix it while you wait.
